Z2 admin (web) console
Spekki
Spekki Posts: 2
First Anniversary
edited June 2020 in Home Router
Anyone else having problems in the Status pages of the console? My "Usage monitor", "Common usage" and "Download traffic statistics" dont show anything. In browser console i can see GET error:
  • workinto
    workinto Posts: 44
    First Answer First Comment First Anniversary
    edited April 2020
    What is your firmware version?
    Do you mean the GUI is blank? Can you share the screenshot?
  • Spekki
    Spekki Posts: 2
    First Anniversary
    After communicating with Zyxel support, the answer to the problem was to do firmware upgrade and factory reset after that. The GUI was blank yes, but as said, after factory reset the console started to work as its supposed to. Thank you anyway :)
