Anyone have performance issues with a NWA1123AC HD
Antman
Antman Posts: 1 image  Freshman Member
edited May 2024 in Wireless
I purchased the AP to replace a Asus router but am getting worse performance from the AP. Ran speed tests from the port the AP is plugged into using the same cable that was connected to the access point got 340Mbps on speedtest.net and fast.com. Getting 310 from the asus router. Max I can get from The zyxel is 200Mbps,  my IPad is connecting to the Zyxel at 975TX 526RX so would expect to achieve at least the same as the Asus.
Any ideas anyone?
  • lodiabai
    lodiabai Posts: 120 image  Ally Member
    Did the channel of two APs the same when you did the test? Did you check the connection RSSI of the station on the AP? Is there any specific setting you configured on the NWA1123-AC HD?
  • Zyxel_Freda
    Zyxel_Freda Posts: 397
    25 Answers First Comment Friend Collector Third Anniversary
    image  Zyxel Employee
    Hi @Antman ,
    The NWA1123-AC HD performance should be better than your test result. So, would you PM the configuration and the logs to me? We'll help to check the details.
    Thanks.
