SSL VPN using USG20-VPN
I need help and I only have a week to figure this out.
I'm currently in the Philippines where my ISP has all my ports blocked. I need to be able to access my network here from my home network in the USA. The reason, I am only in the Philippines once a year and would like to be able to access my network from the USA to see my cameras in my house. I have access to my home in the USA through remote access. So I can test whatever changes I make to see if the VPN will work.
This is sort of what my network looks like. Forgive me but I am very limited on setting up a network. I am just learning how to use the USG20-VPN. I can do remote desktop just fine, port forwarding just fine. But not setting up a SSL VPN.
NOTE: there is an error in my map it says "Smart Wi-Fi" under the ZyXel USG20. It does not have Wi-Fi.
Here is how I have the SSL VPN is setup
Screen shots of the VPN client from the USA
I have tried following YouTube videos I found on the internet on setting up SSL VPN for . But something is not right.
First question: If I am doing remote access to my home in the USA and I try running ZyWall VPN client would it let me? Would the remote desktop block any attempt to VPN?
Second question: Can the Cisco DCP3825 be blocking it somehow? It has WIFi not that that matters. But I saw somewhere that it had VPN in it. It also has some form of firewall.
Third question: Since the Cisco DCP3825 is a router, do I have to do any port forwarding to the USG20 since the WAN address for the USG20 is from the Cisco DCP3825?
Fourth question: I can not access the ZyXel USG20-VPN using remote management. Any thoughts on why I can not see it? I think this is related to the Cisco DCP3825.
Any help would be appreciated. Thank you.
Hi @wrohr15309
Welcome to Zyxel community!
Your question seems to be related to USG products.
I will move your discussion to USG page and you can keep discussion on USG page.
Thanks!
Ryan0 -
Look like you got the wrong VPN client software.
Here the SecuExtender software for SSL VPN dialup to USG.
https://www.zyxel.com/support/DownloadLandingSR.shtml?c=gb&l=en&kbid=M-02111&md=SecuExtender
- 441 Beta Program
- 293 Service & License
