Zyxel USG Flex 100 Question
pilecarls8
pilecarls8 Posts: 1 image  Freshman Member
edited April 2021 in Security
Hi. Does anyone know if the Zyxel USG 100 supports load balancing between multiple WAN links? From what I could gather, you can use the dedicated WAN port for the first link and the sixth port (OPT) for the secondary Internet connection, but can these two be used at the same time?
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,568 image  Zyxel Employee
    Hi @pilecarls8,
    Welcome to Zyxel Community. :)   The Flex 100 does support load balancing between multiple WAN link. you can use OPT interface as 2nd wan interface for load balance. Both Wan also can be used at the same time.
