How can I transfer my server with ZyXel?
planetaPe
I know how to do it, but what should I type in all the boxes. There is the start port, the end port, the translation start port, and the translation end port. What should I type in these boxes?
What is the model of your device? Seems you are going to set a port forwarding rule on a Router.
If you don't need a port range for your port forwarding rule, you can set the start and end port with the number. and set the external port as you want, and set the internal port for the server that it needs, such as FTP for 21, SSH for 22.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
