ZyWall IPSec VPN Client through console/powershell
Hi, I am wondering whether the client supports openning tunnels via command line.
I tried basic `help` switches when launching the executables/renaming them so that I would see some errors but no luck.
Is it possible?
Thanks in advance. Michal-MK
E: could not figure out how to add tags and pressing enter when "Tags" input has focus submitted the answer...
Is it possible?
As far as I know, the software is implemented by TheGreenBow.
You can check if there is a such command to open tunnel in the user guide.
http://www.thegreenbow.fr/doc/tgbvpn_ug_en.pdf0 -
Your .pdf does not say much... but I found this: https://www.scribd.com/document/19124293/TheGreenBow-VPN-Client-Software-Deployment-Guide
(opening it on android somehow tricks its "register to get 30 days free restriction")
from there it seems possible but I have no idea what NamePhase1 is.
It is neither IKE Auth name nor ChildSA name...0
- 215 Nebula Ideas
- 569 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
