Memory leak after upgrading to the latest firmware version for the GS1900-24E?
Hi @Gilad
Could you provide tech support to us so we can check it?
If you have a privacy concern, you can PM me the tech support.
You can download tech support on Maintenance > Configuration > Content > Tech Support
About the attached graph, may I know is it a monitor software?
Thanks for your cooperation
Best regards,
Zyxel_Derrick0 -
Can't post this file, it contain too much private infomation about the network...
attached is another graph from today, I'm using SNMP and LibreNMS software to monitor the memory usage.
The switch restarted itself on Friday evening, if it happens again I'll just downgrade the firmware back to version 2.50.
Hi @Gilad
May I know what OIDs you are polling and the polling interval?
Also, may I know if you could provide the information of "Process Memory" in the tech support to us so we can check it?
Best regards,
Zyxel_Derrick0 -
No sure which OID it's using, I'll try to find out.
'Process Memory' section from 'Tech Support':------------------ Process Memory ------------------total(KB) used(KB) free(KB) shared(KB) buffer(KB) cache(KB)--------------------+------------+------------+------------+------------+------------Mem: 62416 60924 1492 0 2364 24384-/+ buffers/cache: 34176 28240Swap: 0 0 0PID MEM(KB) COMMAND1 276 init2 0 ksoftirqd/03 0 events/04 0 khelper5 0 kthread6 0 kblockd/07 0 pdflush8 0 pdflush9 0 kswapd010 0 aio/011 0 mtdblockd24 0 loop030 0 jffs2_gcd_mtd333 0 jffs2_gcd_mtd444 0 waMon 50045 0 waMon 100057 0 SCHED Thread58 0 LinkMonIsrThrea59 0 Port Monitor Th60 0 Port Security T61 0 Borad Monitor T70 0 STP RX Thread71 0 MSTP FSM Thread72 0 MSTP Routine Th73 0 MSTP Tick Threa76 0 LACP RX Thread79 0 IGMP RX Thread82 0 DOT1X RX Thread83 0 DOT1X RADIUS RX84 0 DOT1X ARP RX Th87 0 Voice VLAN Time90 0 LLDP RX Thread91 0 TX Thread92 0 Timer Thread95 0 RLDP RX Thread96 0 RLDP TX Thread97 0 RLDP Enable Thr150 300 syslogd153 3616 snmpd154 3616 snmpd155 3616 snmpd157 1116 zon163 224 inetd164 1232 polld165 212 klogd166 1184 timed173 1228 ksid179 284 sh180 300 sh182 2616 cli186 1628 boa187 936 boa2222 1228 ksid3782 2320 dispatcher.cgi0 -
This is the log from 'Tech Support' when the switch restarted:5;Sep 03 2020 03:15:45;%Interface-5: Port 6 link up5;Sep 04 2020 01:02:15;%Interface-5: Port 6 link down5;Sep 04 2020 01:02:32;%Interface-5: Port 6 link up5;Sep 04 2020 01:02:35;%Interface-5: Port 6 link down5;Sep 04 2020 01:02:37;%Interface-5: Port 6 link up====== [3: Kernel Log]<0>Kernel panic - not syncing: out of memory. panic_on_oom is selected<4><4> Abnormal reboot [0x32c55080]0
Hi @Gilad
We would like to reproduce the issue
Therefore, besides the OIDS you are polling, we would like to ask again that could you provide tech support to us by "private message" so we can try to find out the root cause?
Or, could you remove the private part and send the tech support to us by "private message"?
Best regards,
Zyxel_Derrick0 -
Hi Derrick, I sent you the tech-support file by private message.0
Hi @Gilad
Thanks for providing tech support to us
We will try to reproduce the issue and if there is any update will let you know asap
Best regards,
Zyxel_Derrick0 -
Thanks you Derrick.0
CPU and memory usage in the last 3 days. Seems like the GS1900-24E SNMP process can't even return the values... I wanted to generate another tech-support file, but I can't even access the web GUI. Going back to firmware version 2.50.0
- 3K Nebula
- 231 Nebula Ideas
- 6.6K Security
- 670 USG FLEX H Series
- 360 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 307 Service & License
- 500 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
