Using SSL VPN / SecuExtender via IPv6
mapo
mapo Posts: 3 image  Freshman Member
edited April 2021 in Security
Hi all,
we would like to use SecuExtender as personal VPN access clients to our network. The firewall we are using is a ZyWall 110. The firewall only has a public IPv6 address, the IPv4 address is a private one. (DSL-Lite Stack)
I set up SSL VPN with the manualls and SecuExtender can connect to the IPv4 address, but not to the IPv6 address. Is it possible to use the SecuExtender via IPv6 and how do I enable it?
Thank you
Marc
