What's New for ZLD4.60 patch 1 (available on Dec. 15)
Hi @bind
So far we didn't enhance the SSL VPN performance yet. If you would like to better VPN performance you can choose L2TP. Because of the Vulnerability issue of CVE-2020-29583, we strongly suggest you upgrade to ZLD4.60 patch1.0 -
Hi Jeff, thanks. Enhance the ssl vpn performance would be a good thing. Any plans for that?0
Hello,we run 2 ZyWALL 110 in HA Pro mode. 4.39 and 4.60 system runned Ok. SInce we upgraded from 4.60 to V4.60(AAAA.1) we get zysh daemon crashes every day (see below).At that stage Internet access and IPSec VPN connections are still working but it is impossible to make an https connection to manage the firewall or to make a SSL VPN connection.The only way to make the firewalls work again is to either do a Break + b + atgo trough serial console port for each firewall at a turn or to turn off and on power from both firewall devices.Any hint on how to solve such issue ?Unable to connect ZySH daemon
command function history:
0x10010dd8 argc:1 args:
0x10010530 argc:1 args:
0x10010a38 argc:1 args:
0x10198250 argc:4 args:show users all
0x10010c60 argc:2 args:exit
0x102deee0 argc:6 args:show idp statistics ranking signature-name
0x10078de8 argc:4 args:show interface base
0x10255b08 argc:4 args:show zone binding-iface
0x1007fc70 argc:3 args:show interface-name
0x10079510 argc:5 args:show interface summary base
0x10048320 argc:3 args:show port-grouping
0x1022f440 argc:4 args:show device-ha status
0x1022f618 argc:4 args:show device-ha mode
0x10246f60 argc:4 args:show device-ha2 status
0x1024a6c8 argc:4 args:show device-ha2 interfaces
0x1024c790 argc:4 args:show device-ha2 mode
0x100a2da0 argc:4 args:show interface cellular
0x102faa28 argc:4 args:show firewall block_rules
0x103aa2f8 argc:2 args:run
later same day got an ATP200 running V4.60(AAAA.1) which crashed the same way :-( "Unable to connect ZySH daemon"0
Hi @Helpdesk_ITPhM
It was fixed in the current release, the firmware download link will be shared with you in private message.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
