Let's encrypt - SSL certificate
mjr
Hello!
Is "let's encrypt" SSL certificate support planned on the USG40 (and higher)?
With which version is this activated?
BR, MJR
BR, MJR
14
You always can import certificate/private key with pkcs12 format into the USG, not just let's encrypt.
I know that you can import certificates.
For some customers it is interessting to be able to use "lets encrypt" certificates.
Other devices, such as NAS from QNAP, are already prepared for this.
2 -
I did import let's encrypt certificate on my USG110 for device GUI management.
And it works.
Hi zyman2008!
How long is the certificate valid? Is the renewal process automatically done or do you have to manually update the certificate?
BR; mjr0 -
I'm using certbot on my raspberry Pi behind the USG to auto renew the certificate from let's encrypt.
Of course, I need manual import the renewal certificate into my USG through the GUI.
Since it's just take less than 5 mins. every 3 months, so that not a problem, for me.
If USG can support import certificate via FTP service. Than I can automation all the process.
I think it would be a very helpful feature if the zywall could handle let's encrypt certificated automatically, without any user interaction. -> FEATURE REQUEST4
@mjr
The request " USG Series could handle let's encrypt certificated automatically", I would like to move your request to the ideas section."
Charlie
6 -
I am just posting to register my vote in favor of adding inbuilt Let's Encrypt functionality. Registered the account on the forum to do so.3
Did anyone figure out how to import Let's Encrypt generated certs? Could not get it to work with these instructions. Does the key.pem need to be coverted to a pkcs12?
Combining key and certificate into a pkcs12
PKCS#12 incorrect password error #84
I only pack the certificate and private key into PKCS12 file.
# openssl pkcs12 -export -out myusg.p12 -inkey private.key -in certificate.crt
Then import root & intermediate certificate into Trusted Certificated in USG.
And import PKCS12 file into My Certificated in USG. (you need to provide the password of p12 file
That's it.0
- 243 Nebula Ideas
- 6.8K Security
- 782 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 528 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
