ATP200 FIRMWARE V.4.60((ABFW.1) Email Security doesn't work
Hi @CELCOMPO
You can refer to the following configuration tutorial of anti-spam.
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=015556&lang=EN
Good morning, in the ATP 200 with the latest frimware there's no UTM profile configuration. Any other ideas?0
Hi @CELCOMPO
You can refer to the following steps:
Set up the Email Security on ATP Series
In the ATP Series, go to CONFIGURATION > Security Service> Email Security; Enable this feature on General Settings page.
Select from the list of available Scan Options and desired Log type whether to have the ATP Series generate a log (log), log and alert (log alert) or neither (no) by default when traffic matches this policy. Click Apply to save the configuration
1. CONFIGURATION > Security Service> Email Security
CONFIGURATION > Security Service> Email Security>Enable Check DNSBL
Press Add and enter the DNSBL Domainfor a DNSBL service (zen.spamhaus.org in this example). Click Apply.
2.Go to CONFIGURATION > Security Service> Email Security> Black/White List >Enable Check Black List to have the ATP Series treat e-mail that matches (an active) black list entry as spam.
click the Add icon. A pop-up screen will appear allowing you to configure Content (Subject, IP/IPv6 Address, E-Mail Address and Mail Header), Use wildcards (*) to configure Mail Subject Keyword. (*sell* in this example). Click OK to return to the General screen.
Test the result
1.Send the mail subject with “sell”.2. You will receive the mail subject with [Spam] tag.
3. Monitor > Log > View Log to check alert log.
4. Monitor > Security Statistics > Summary to check spam nail amount.
Thank you for your comment and suggestion. I have already done this and used all the settings as in the screenshots.The Email Security doesn't block the example mail and doesn't log anything.0
Hi @CELCOMPO
Can you describe your e-mail transportation method?
Currently the Anti-spam doesn't support scanning the encrypted e-mail format,
it supports SMTP/POP3 unencrypted format.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
