SBG3300 used as a wireless Access Point Time is incorrect
Hi
I have 2 SBG3300-N000 one is my ADSL router, I have another SBG3300-N000 connected to this via LAN acting as a wireless Access point (WAP).
The WAP time is incorrect, the time server's on the WAP are set.
It wouldn't be a problem but I want to use WiFi Scheduling for the children.
Hello @Terry999
Do you know what version of firmware your devices are running?
According the firmware release notes available in ftp://ftp.zyxel.com/SBG3300-N000/firmware/ there was a time synchronisation bug fixed in 2016.
The newest firmware was released in 2018, see screenshot below.
as 1.01(AADY.9)C0
The user guide at ftp://ftp.zyxel.com/SBG3300-N000/user_guide/ might help you.
I hope that this is helpful.
Kind regards,
Tony0 -
Thanks Tony for taking the time to investigate.
On Both my routers
Current Firmware Version: V1.01(AADY.9)
Current WWAN Package Version: 1.15
So it looks like they are up to date.
The time on the SBG3300 acting as a WAP is 22 Feb 2018 - the year of the update!!
Hello @Terry999
Thanks for your reply.
You may have found another bug.
My last thought is what happens if you set the First NTP time server to pool.ntp.org
- this is what I have working in my Zyxel router.
- other NTP providers may be refusing to provide time for security reasons.
Kind regards,
Tony0 -
Hi Tony
Changed it to pool.ntp.org and rebooted, its gone back a month earlier now it's 01 Jan 2018.
Maybe Time is actually 2yrs earlier in the WAP? A Star Trek style Space Time distortion?
- 431 Beta Program
- 2.6K Nebula
- 168 Nebula Ideas
- 6K Security
- 366 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 265 Service & License
- 409 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
