Wan to device access
lucavengers
Hello, I want to reach a local camera server from internet through my usg2O ZyXEL device.
Connection seems to be blocked by a firewall rule and i'm not able to see wich one.
I configure the NAT with port forwarding.
Need help please.
Need help please.
You need to make a firewall rule from WAN to LAN1 to the camera server IP0
I did the rule on Policy control because idon't have firewall on this access, I can access at the ZyXEL but i Don't go on my server I stay on the login page.
I Don't know how to forwarding port to go on my server
ZyXEL login page*
You need to make a Virtual Server rule in NAT
incoming interface = WAN
external IP = make address with INTERFACE IP = wan1
internal = to your camera server
than the ports to the camera server
POLICY CONTROL:
NAT:
i did this but i don't know if my configuration is good because i can't access to my server
i do that, i think its better but doesn't work
Policy control
NAT
You could do two NAT rules one for 80 and 443 but what you done should work.
Does WAN1 have a WAN IP and is not getting 192.168.xxx.xxx ?
Run a port scan for 80 and 443
https://www.grc.com/x/ne.dll?bh0bkyd2
Does the camera server setup with a gateway to LAN1? or is just IP and subnet?
i think i found the problem, i have an other equipement who block with a firewall0
- 234 Nebula Ideas
- 6.7K Security
- 709 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 314 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
