SBG3300 used as a wireless Access Point Time is incorrect
Terry999
Terry999 Posts: 3 image  Freshman Member
edited April 2021 in Security
Hi
I have 2 SBG3300-N000 one is my ADSL router, I have another SBG3300-N000 connected to this via LAN acting as a wireless Access point (WAP).
The WAP time is incorrect, the time server's on the WAP are set.
It wouldn't be a problem but I want to use WiFi Scheduling for the children.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @Terry999
    Do you know what version of firmware your devices are running?
    According the firmware release notes available in ftp://ftp.zyxel.com/SBG3300-N000/firmware/ there was a time synchronisation bug fixed in 2016.
    The newest firmware was released in 2018, see screenshot below.
    as 1.01(AADY.9)C0
    The user guide at ftp://ftp.zyxel.com/SBG3300-N000/user_guide/ might help you.
    I hope that this is helpful.
    Kind regards,
         Tony
  • Terry999
    Thanks Tony for taking the time to investigate.
    On Both my routers
    Current Firmware Version: V1.01(AADY.9)
    Current WWAN Package Version: 1.15
    So it looks like they are up to date.
    The time on the SBG3300 acting as a WAP is 22 Feb 2018 - the year of the update!!
  • tonygibbs16
    Hello @Terry999
    Thanks for your reply.
    You may have found another bug.
    My last thought is what happens if you set the First NTP time server to pool.ntp.org
        - this is what I have working in my Zyxel router.
             - other NTP providers may be refusing to provide time for security reasons.
    Kind regards,
         Tony
  • Terry999
    Hi Tony
    Changed it to pool.ntp.org and rebooted, its gone back a month earlier now it's 01 Jan 2018.
    Maybe Time is actually 2yrs earlier in the WAP? A Star Trek style Space Time distortion?
