Zywall 110 Firmware upgrade
Raffa
Raffa Posts: 2 image  Freshman Member
edited April 2021 in Security
Hello, Where can I find a firmware update history for the ZyWall 110? My device is running V4.10 currently and I need to know how much work I need to do to get it up to date!
Thank You!
  • Zyxel_Stanley
    Hi @Raffa
    You can upgrade firmware by this steps:
    410AAAAC0 > 420AAAAC0 > 430AAAAC0 > 435AAAAC0 > 438AAAAC0 > 460AAAAC1.
    I will send 4.20/4.30/4.35 firmware to you by private message.
    The other versions, you can download them after logged on to Myzyxel.com.
  • Raffa
    Thank You!
  • EricLogsdon
    EricLogsdon Posts: 8 image  Freshman Member
    First Answer First Comment Sixth Anniversary
    Zyxel_Stanley,
    I also need to perform the same upgrade (ZyWALL 110 running 4.10). Can you send me the 4.20/4.30/4.35 versions as well?
    Thanks so much.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @EricLogsdon
    I will send private message to you.
    Please check your inbox.
    Thanks.
  • EricLogsdon
    Thank you!
  • RichardA
    RichardA Posts: 1 image  Freshman Member
    I also need to perform the same upgrade (ZyWALL 110 running 4.15). Can you send me the 4.20/4.30/4.35 versions as well?
