USG and Plume WLAN
I'm using Plume together with a USG40 firewall. The only way I got it to work is by switching it to router mode. However, now the WLAN is on a different subnet than the business network which means no access to network resources. Has anyone successfully used Plume WLAN together with USG40 in bridging mode? DHCP is delivered by Windows (not by USG40), which could also be the reason why bridge mode didn't work.In Routing mode Plume passes out it's own IP addresses. Interesting: Before I had a single Zyxel access point and had no problem at all. Plume support not very helpful, so I thought I'd ask the Zyxel community.
Hi @VPNRob
Thanks for your feedback.
In your case, we suggest you configure WiFi router to bridge mode.
As long as the WiFi router connects to USG40 LAN port, it should be working without additional configurations on USG40.
Following example is Zyxel NBG router which in bridge mode connect to USG60W can give you a reference.
https://businessforum.zyxel.com/discussion/4759/usg60w-access-to-lan-from-additional-wap
You may check your WiFi router configuration or contact with WiFi router manufacturer to ask if there is any other user encounter this symptom.
- 588 USG FLEX H Series
- 476 News and Release
