Zywall 110 Firmware upgrade
Thank you!1
Hi @Raffa
You can upgrade firmware by this steps:
410AAAAC0 > 420AAAAC0 > 430AAAAC0 > 435AAAAC0 > 438AAAAC0 > 460AAAAC1.
I will send 4.20/4.30/4.35 firmware to you by private message.
The other versions, you can download them after logged on to Myzyxel.com.
Thank You!0
Zyxel_Stanley,
I also need to perform the same upgrade (ZyWALL 110 running 4.10). Can you send me the 4.20/4.30/4.35 versions as well?
Thanks so much.
Thank you!1
I also need to perform the same upgrade (ZyWALL 110 running 4.15). Can you send me the 4.20/4.30/4.35 versions as well?
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
