Wan to device access
lucavengers
lucavengers Posts: 6
image  Freshman Member
edited April 2021 in Security
Hello, I want to reach a local camera server from internet through my usg2O ZyXEL device.
Connection seems to be blocked by a firewall rule and i'm not able to see wich one.
I configure the NAT with port forwarding.
Need help please.
    PeterUK Posts: 4,837
    image  Guru Member
    You need to make a firewall rule from WAN to LAN1 to the camera server IP
  • lucavengers
    I did the rule on Policy control because idon't have firewall on this access, I can access at the ZyXEL but i Don't go on my server I stay on the login page.
    I Don't know how to forwarding port to go on my server
  • lucavengers
    ZyXEL login page*
    image  Guru Member
    You need to make a Virtual Server rule in NAT
    incoming interface = WAN
    external IP = make address with INTERFACE IP = wan1
    internal = to your camera server
    than the ports to the camera server
  • lucavengers
    POLICY CONTROL:
    NAT:
     i did this but i don't know if my configuration is good because i can't access to my server
  • lucavengers
    i do that, i think its better but doesn't work
    Policy control
    NAT
    image  Guru Member
    edited January 2021
    You could do two NAT rules one for 80 and 443 but what you done should work.
    Does WAN1 have a WAN IP and is not getting 192.168.xxx.xxx ?
    Run a port scan for 80 and 443
    https://www.grc.com/x/ne.dll?bh0bkyd2
    Does the camera server setup with a gateway to LAN1? or is just IP and subnet?
  • lucavengers
    i think i found the problem, i have an other equipement who block with a firewall
