Content Filter - fw: V4.60
2»
  • pm24
    pm24 Posts: 4 image  Freshman Member
    My solution:
    I had same problem on FLEX200,USG40W and ATP500, all with fw.4.60.
    I did this steps for repair.
    1. backup "startup-config" configuration
    2. delete all configuration files
    4. reset device to default /via button on device/
    4. upload configuration- backup from step no.1
    After completing these steps, the content filter started working properly.
    In the following days, I want to apply these steps to the other two ATP500 devices.
    After I will give you feedback.
    I am trying to solve this problem for a few days with
    Mr Jan Zelman (Zyxel Support Campus EMEA).
    He told me today, that his other customer has the same problem.
    And that this is probably a bug in the FW4.60.
    If the content filter will work after performing the above steps for it as well. He will then contact HQ department about this error.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,435 image  Zyxel Employee
    edited January 2021
    Hi @pm24
    Thanks for share your explain of it.
    We have addressed this issue, and it fix it the future release.
  • IT_Field_Support
    IT_Field_Support Posts: 97 image  Ally Member
    We also noticed many problems with 4.60 and we had to rollback to 4.39.
