getCorpPlanZoneByIB failed - My mistake, now what?
AndreaTosi
Hi ... I think I made a mistake cleaning up zones.
Deleted a zone from org profile before realizing it was defined in one of my firewalls, now when I try to edit its ports i get a blank screen with "getCorpPlanZoneByIB failed" and the zone internal ID... can't edit ports and can't remove the missing one:
Recreating it would just create another internal ID so i don't think it's ok...
There was no warning when i deleted that zone from org, but now i'm locked out...
Re-provisioning firewall or any suggestion?
Thanks,
Andrea
Thanks,
Andrea
... since I was in a hurry, as usual, I unlinked that device from the problematic site, then relinked it and recreate from scratch its configuration...
Just curious if there was a better option.0 -
Hi @AndreaTosi
Is this symptom still exists after you relinked this device to the Orchestrator? Would you authorize us to check further from the Nebula Orchestrator ?
Here it is our account: cso_security@zyxel.com.tw
Please also let us know the GROUP/ORGANIZATION/SITE names
Regards,0 -
Hi, all went back to normal relinking and reconfiguring by scratch that device.
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
