i have es1100-16 when i hook up to my wifi router it kills the wifi
Bill_12
Bill_12 Posts: 1 image  Freshman Member
edited August 2022 in Switch
router works but knockes out my wifi
    I can't see how its affecting your wifi
    if nothing is connected to the switch and you just link the switch up to your router doez that kill you wifi? Try another cable.
