Switch GS1200-8 Series - V2.00 Patch 0 Firmware Release
Zyxel_Adam
Zyxel_Adam Posts: 429 image  Zyxel Employee
Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
edited July 2021 in Switch New Release
Zyxel Switch GS1200-8 Series
Release Note
January, 2021
Firmware Version on all models
(Click Hyper link to download the firmware directly)
Zyxel GS1200-8        - V2.00(ABME.0)
Zyxel GS1200-8HPv2    - V2.00(ABMF.0)
New Feature and Enhancements
No.
1.
Support port isolation
2.
Support bandwidth control
3.
Support management VLAN
4.
Support system up time
Bug fix
No.
Bug fix
1.
[eITS#200700086] IGMP control packet causes loop
Please refer to the Download Link for more details.
Adam
  • lfos
    lfos Posts: 2 image  Freshman Member
    A bug is introduced with the firmware V2.00(ABME.0): is not possible to set the management address in the range 10.0.0.0/8 anymore.
    Problem in the web ui lies at least in the checkIP(ip) function, the provided new regular expression :
       var exp=/^([1-9]{1,2}|1\d\d|2[0-2][0-3])\.(\d{1,2}|1\d\d|2[0-4]\d|25[0-5])\.(\d{1,2}|1\d\d|2[0-4]\d|25[0-5])\.(\d{1,2}|1\d\d|2[0-4]\d|25[0-4])$/;
    clearly don't match the addresses starting with 10.
    Previous firmware release works correctly.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,607 image  Zyxel Employee
    Hi @lfos
    Welcome to Zyxel community.
    Sorry for the inconvenience,
    We've posted a workaround to resolve this issue with a hotfix firmware version, you may use the following link to download it: https://businessforum.zyxel.com/discussion/9591/fixed-gs1200-8-8hpv2-management-ip-address-issue#latest
    After upgrading the hotfix version, switch should be able to use 10.0.0.0/8 subnet.
    Melen
    Zyxel Melen
  • lfos
    Hi @Melen
    thank you for the quick response,
    hotfix firmware version works as expected.
