Switch GS1200-8 Series - V2.00 Patch 0 Firmware Release
Zyxel_Adam
Zyxel Switch GS1200-8 Series
Release Note
January, 2021
Firmware Version on all models
(Click Hyper link to download the firmware directly)
Zyxel GS1200-8 - V2.00(ABME.0)
Zyxel GS1200-8HPv2 - V2.00(ABMF.0)
New Feature and Enhancements
No. |
New Feature and Enhancements |
1. |
Support port isolation |
2. |
Support bandwidth control |
3. |
Support management VLAN |
4. |
Support system up time |
Bug fix
No. |
Bug fix |
1. |
[eITS#200700086] IGMP control packet causes loop |
Please refer to the Download Link for more details.
Adam
A bug is introduced with the firmware V2.00(ABME.0): is not possible to set the management address in the range 10.0.0.0/8 anymore.Problem in the web ui lies at least in the checkIP(ip) function, the provided new regular expression :var exp=/^([1-9]{1,2}|1\d\d|2[0-2][0-3])\.(\d{1,2}|1\d\d|2[0-4]\d|25[0-5])\.(\d{1,2}|1\d\d|2[0-4]\d|25[0-5])\.(\d{1,2}|1\d\d|2[0-4]\d|25[0-4])$/;clearly don't match the addresses starting with 10.Previous firmware release works correctly.0
Hi @lfos
Welcome to Zyxel community.
Sorry for the inconvenience,
We've posted a workaround to resolve this issue with a hotfix firmware version, you may use the following link to download it: https://businessforum.zyxel.com/discussion/9591/fixed-gs1200-8-8hpv2-management-ip-address-issue#latest
After upgrading the hotfix version, switch should be able to use 10.0.0.0/8 subnet.
Melen
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 459 News and Release
- 4.3K FAQ
- 97 Security Highlight
