vpn50 sessions limit- suspicious connections
I dont know zyxel routers too much, so please help me - is it normal behevior that after configuriing reporting on Zyxel VPN50 Device (latest fw 4.62) im geting a lot of messages like that below.
I know that I can change or disable that session limit (per device or per IP), but I'm worry that I cannot trace those IPs source (f.e.185.151.30.162) in Session Monitor.
Is there a way to get a more datailned log or realtime info about that connections?
And what is the best way to make a blacklist and put there suspicious IP addresses to block any connections from them?
No. Date/Time Source Destination
Priority Category Note
Message
1 2021-02-03 14:19:23
notice system
Sending event/alert log to mail server has succeeded.
2 2021-02-03 14:19:23 188.44.124.6 my_WAN_IP
warn sessions-limit ACCESS BLOCK
Maximum sessions per host (1000) was exceeded. [count=255]
3 2021-02-03 14:19:23 185.151.30.162 my_WAN_IP
Maximum sessions per host (1000) was exceeded. [count=255] 0
Maybe you can try this CLI to track device connection status.=)
Router> debug system show conntrack | match "185.151.30.162"
Hi @MStil(1). You can issue this command to trace real-time connection of IP “185.151.30.162”Router> debug system show conntrack | match "185.151.30.162"(2). If you would like to reject any traffic from a Block IP group.You can add Block IP Group and security policy.First, add block IP address objects and put them into a group.
Second, add a security policy.BTW, you may set log alert if those block IPs connect to your VPN50 alert log will be generated.
- 603 USG FLEX H Series
- 481 News and Release
