firewall turning on vpn50
I've got a simply question about turning on firewall rules- my client has zyxel vpn50 device, and as I see there is no check on Enable Policy Control, does it means that all rules are not working and router is allowing for any data transfer?
Can I safely change Action in (last) default rule to ALLOW, and then Enable Policy Control? (router is working as VPN server, it has some port forward rules in NAT section)?
I ask becouse router has open Remote Managment (443) port which I want to disable it on WAN interface (I can do it remotely ond I dont want to screw his rules and internet sharing )..
Best Answers
It is not safe to change the default rule to ALLOW. If you want to disable Remote Management (443) port on WAN interface, just remove HTTPS from the group object Default_Allow_WAN_To_ZyWALL.
Thank you for assistance, everything , evrything goes well1
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 318 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
