Local static routes not working
Firmware V4.62
So have a Zywall 110 doing the static routes and USG60 with a LAN2 SNAT none to gateway 192.168.255.202 firewall rules have been allowed no blocked logs when doing ping testing.
Here is a cut down layout of the network.
https://us.v-cdn.net/6029482/uploads/editor/ns/vwhin1wi0ytg.png
192.168.2.2 has not problem getting to the internet
So first problem is 192.168.255.193 can't ping 192.168.2.2 so leave that running with ping -t go to 192.168.2.2 and try to ping 192.168.255.193 first ping fails then success but with some timeouts. I then go back to 192.168.255.193 and its pinging 192.168.2.2 but with some timeouts I stop 192.168.2.2 from pinging 192.168.255.193 go back to 192.168.255.193 and it stops pinging 192.168.2.2 with and times out.
Some more testing:
So I have routing rule for 192.168.2.0/24 and 192.168.255.193 to go from LAN1 to OPT SNAT outgoing-interface if Inactivate them 192.168.255.193 can now ping 192.168.2.2 but 192.168.2.2 to ping 192.168.255.193 still with some timeouts until I checked “Use IPv4 Policy Route to Overwrite Direct Route” on USG60 this forwards the packet 192.168.255.193 to the the gateway 192.168.255.202 Direct.
I now have to solve getting internet to 192.168.255.193 but allow it to ping 192.168.2.2
Edit: so I have made a rule above LAN1 to next hop OPT SNAT outgoing-interface by
incoming = Interface
member = lan1
destination address 192.168.2.0/24
next hop = auto
Source network address translation = none
I now have a problem with “Use IPv4 Policy Route to Overwrite Direct Route” on the USG60 where my other routing rules stopped working. :'(
so this is now solved.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
