USG60W - IP Binding Enabled | IP Fixed not allowed
Jigen
Jigen Posts: 13 image  Freshman Member
edited April 2021 in Security
Dear All,
it seems that enabling IP BINDING on my LAN interaface all the PCs with FIXED IP connected to the zyxel can't access to internet.
Do you know anything about it ?
Thanks,
  • Zyxel_Tobias
    Zyxel_Tobias Posts: 208 image  Zyxel Employee
    Hi Jigen,
    the "Enable IP/MAC Binding" and "Static DHCP Table" is not bind to each other from Feature.
    If you just fill out the "Static DHCP Table" with your reservations, that will work, and ALL Clients internet allow.
    If you enable "IP/MAC Binding" it will ONLY allow the clients in Table and block all other.
«1
  • Zyxel_Tobias
    Hi Jigen,
    enable this feature will cause this, due to only entries in the list will be valid.
    You can just configure IP/MAC Binding list (Static Entries) and keep the feature self disabled.
    https://support.zyxel.eu/hc/en-us/articles/360002858959-USG-Series-IP-MAC-Binding
    Kind Regards,
    Tobias
  • Jigen
    Hi Tobias,
    how can I configure IP/MAC Binding List keeping the feature disabled ?
    The ip binding will happen if its not checked ?
    Thanks,
  • Zyxel_Tobias
    Hi Jigen,
  • Jigen
    Hello Tobias!
    Thanks for clarify it!
    Regards!
  • Jigen
    Tobias! Last question... how can I get a list of ALL the machines connected to my network and see assigned ip ?
    Thanks,
  • Zyxel_Tobias
    Hi Jigen,
    in Dashboard Page (when you login to device) there is a DHCP Table, you can click here and see all assignments and click the right box to reserve the IP (auto copy to the table).
    Kind Regards,
    Tobias
  • Jigen
    Hello Tobias,
    I would like to see ALL the PCs connected - even the ones with STATIC IP.
    Let me know,
  • Zyxel_Tobias
    this is same feature, just scroll down to bottom to see reservations.
  • Jigen
    I am missing the ones which have not used DHCP server assignment.
    They are not listed where you showed me.
    Thanks,
    PeterUK Posts: 4,282 image  Guru Member
    Let me know,
    You will not see STATIC IP connected devices
