IGMP Issue with USG FLEX 200
Savannah_CH
Hi all,
I bought the new USG Flex 200. I have done a upgrade from a USG60W. So far I was able to take over the configuration and so far it works very well.
Only one thing which is not working is Live-TV behind the FW. I configured the the IGMP Settings according the Manuel which was provided by Studerus Switzerland.
Reply is working fine the issue is for Live-TV during a channel change. For few seconds after changing the TV-channel I have green pixel/frames and then it is working fine.
If I'm using a other FW like Pfsense with exactly the same setup or in other words using the same infrastructure I have no issues. I know it is nothing which is really important I can connect the STP directly to the ISP router but it is not my favorite setup.
Any good idea I rally would appreciate.
Many Thanks
Br, Francis
Many Thanks
Br, Francis
Hi Francis,
welcome in our Forum.
Nice to see you upgrade your hardware to next generation firewall.
It seems the issue could be located to Switzerland market and or ISP. And config is dedicated for that.
May you are fine, I convert your concern into a Support Ticket and assign this to Studerus Team?
I´m pretty sure, they have the right tips and tricks to help you out.
Let me know if you are fine with that, and then we can proceed here.
Kind Regards,
Tobias0 -
Hi Tobias,
thanks for your answer.
I had already a open ticket with the Studerus Team, but all the tips they provided didn't help to solve the issue. I suggest then to close the ticket as it is nothing that is really urgent.
But it would be anyway good if we can solve that issue and i'm happy to help here with remote session etc.
Br, Francis0 -
HI Francis,
please let me know Ticket Number, so I can look into it.
Thanks.
Kind Regards,
Tobias0 -
Hi Tobias,
sure the ticket number was 190906.
Many Thanks for your support.
Br,
Francis0 -
Hi Francis,
we will have another look into it and you´ll receive a update soon.
Thanks.0
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
