IPv6 addresses in logs are hidden or cut [solved]
FrankLauer
Posts: 49 Freshman Member
When I receive mail log the IPv6 address is always cut to about 20 chars.
Like that I can't identify the source of problems. I can't see the full address nor ports.
1 2021-02-08 09:26:58 2a01:****:****:9a50:61 2600:****:5306:7300:: <br> warn sessions-limit ACCESS BLOCK
When I open a log file from USB stick, the IPv6 address is empty at all.
2021-02-08 09:26:58, , , warn ,sessions-limit ,ACCESS BLOCK , vlan50 , , , Maximum sessions per host6 (2000) was exceeded.<br>
Well, this forum doesn't let me insert plain text very well.Here again the log lines from mail and USB stick.1 2021-02-08 09:26:58 2a01:****:****:9a50:61 2600:****:5306:7300::
warn sessions-limit ACCESS BLOCK2021-02-08 09:26:58, , , warn ,sessions-limit ,ACCESS BLOCK , vlan50 , , , Maximum sessions per host6 (2000) was exceeded.
Hi @FrankLauer
You can try to enhance session limit:
https://support.zyxel.eu/hc/en-us/articles/360001390354-Connection-is-slow-drops-sometimes-on-USG-what-could-it-be-Session-Limit-
Let me know if it works or not.
Kind Regards,
Tobias0 -
Thanks for reply, but the question was how to show the full IPv6 addresses in logs.In log mails they are cut, on USB stick they are hidden (blank) at all.Additionally I saw today that in the traffic log files the IPv6 traffic is missing at all.0
HI Frank,
it maybe GDPR related, due to some logs may (during initial Phase) are half anonymous.
Can I create a Support Ticket on that for you?
Our Team will look into solution for you then. Let me know if I can use your mail address.
Thanks.
Kind Regards,
Tobias0 -
Please open a support ticket.The IPv4 addresses are also fully visible. In a security device GDPR shouldn't have priority. Common practice is to offer a setting which allows different options to save addresses (hidden,limited,full).
But as I just added in above comment, in traffic log (on USB stick) I miss IPv6 traffic at all.
Hi @FrankLauer
Thanks, someone from our Support Team will contact you soon to figure it out.
Kind Regards,
Tobias0 -
Hi @FrankLauerYou can upgrade to V4.62WK02 firmware and to see if this symptom still appears.Thanks.0
I managed to upgrade today to 4.62(AAPI.0) on the USG210.But still no difference.Mail log:128 2021-02-21 09:38:22 2001:16b8:xxxx:1600:c29:2e06:db05:8d60: 2a01:xxxx:xxxx:9a50::65:443
alert secure-policy ACCESS BLOCK
Match default rule, DROP- On the first IPv6 address the port is missing because the string size is limited.System log on USB:2021-02-21 09:38:22, , , alert ,secure-policy ,ACCESS BLOCK , wan1 ,wan1 ,tcp , Match default rule, DROP- The IPv6 addresses are missing completely.
Today I installed the firmware V4.62(AAPI.0)ITS-WK02-r98140 and as far as I can see, it's fixed. Thank you very much.
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 98 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 922 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 975 Nebula FAQ
- 426 Security FAQ
- 238 Switch FAQ
- 212 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
