USG60W - IP Binding Enabled | IP Fixed not allowed
You can also with IP Binding Enabled use the Exempt list in network > IP/MAC Binding > Exempt list tab for static IP's. Its best to keep static IP devices out of the DHCP range.0
Hi @Jigen,
I´m not pretty sure where your issue is?
On Dashboard - DHCP Table it will give you a list of all valid DHCP Request.
It will show you the connected clients + static IP reservations (in the end)
Here you can see if no "select" is on the end, it´s not static, if checkbox is checked = static.
If you want go for live clients, you may run CLI commands in Webconsole or SSH:
ftp://ftp.zyxel.com/USG110/cli_reference_guide/USG110_11.pdf
If you still missing something, may you post a feature request in Idea section.
Kind Regards,
Tobias0 -
I am exactly looking for ALL THE LIVE CLIENTS connected to the USG 60W .....Zyxel_Tobias said:Hi @Jigen,
Kind Regards,
Tobias
I didnt think that was such strange request
Hi Jigden,
you may go to Monitor - Session Monitor and looking by Source IP, if your client doing traffic you will find it, if not it may also hide for firewall.
Kind Regards,
Tobias0 -
Only by DHCP can the USG see the IP and MAC clients with static IP not by DHCP will not be seen how ever the idea you want is see IP and MAC to the USG gateway list but you will not see a name for the device only IP and MAC however IP Binding enabled may not show clients with static IP's not by DHCP. The other way is for USG to ARP the subnet to find IP and MAC.
- 603 USG FLEX H Series
- 480 News and Release
