ATP500 hangs - 3 reboots in one day
neoforma
neoforma Posts: 9 image  Freshman Member
edited April 2021 in Security
Hi! Since today our ATP500 hangs randomly. I had to reboot (switch off and on!) it for three times today. The ATP Web GUI doesn't work.
A few minutes before i get Alert Mails:
  • temporary working folder filesystem usage reaches 97%
  • App Watch Dog: asd is dead
  • App watch dog stop to recover asd. Daemon state: dead
i viewed the ATP for some time. The cpu is between 5 and 20%, the ram is about 33%, the flash memory was about 18%.
Running firmware: 4.60
What can i do?
Rudolf
  • Zyxel_Tobias
    Zyxel_Tobias Posts: 208 image  Zyxel Employee
    Hi @@neoforma
    thank your for your long and detailed post.
    Today we encounter an issue with one signature, can cause in rare condition abnormal behavior on your ATP firewall.
    And you was one of the lucky few people, which seems run into this issue today.
    We already roll out a fix via Cloud signature update, but let me share the steps with you.
    -> Reboot the device if you can´t login anymore
    -> Go to Configure -> Licensing -> Signature Update
    -> Update App Patrol signature from 2021 version to 2020 version (just execute)
    -> Reboot device after signature is sync finished
    The issue is gone then, and the CPU will continue work smoothly as expected.
    We are very sorry, that you run today into these issue and we have already adjust our QA to include the mention "UTM Dashboard" process deeper into signature release testing.
    Have a good weekend.
    Kind Regards,
    Tobias
  • neoforma
    Hi Tobias, i made the steps you explained. After 20 min. the ATP500 hangs again. The signature is 2020 (i checked). What should i do?
  • neoforma
    Info: i updated to 4.62. But there is still no change.
  • neoforma
    The following mails i received before:
    No.  Date/Time           Source                 Destination
         Priority            Category               Note
         Message
    1    2021-02-12 21:09:24
         alert               system                 App Watch Dog
         App watch dog recover asd dead at the 2 time
    2    2021-02-12 21:09:24
         asd is dead at Fri Feb 12 21:09:24 2021
    3    2021-02-12 21:09:23
         App watch dog recover asd dead at the 1 time
    4    2021-02-12 21:09:22
         asd is dead at Fri Feb 12 21:09:22 2021
         Message
    1    2021-02-12 21:09:25
         App watch dog recover asd dead at the 3 time
    2    2021-02-12 21:09:25
         asd is dead at Fri Feb 12 21:09:25 2021
    3    2021-02-12 21:09:26
         asd is dead at Fri Feb 12 21:09:26 2021
    4    2021-02-12 21:09:26
         Message
    1    2021-02-12 21:09:34
         Message
    1    2021-02-12 21:10:36
         alert               zysh                   zysh daemon
         ZySH daemon is busy
  • Zyxel_Tobias
    Hi @neoforma
    This is different issue from what we know by today.
    Can you try install this firmware and let me know result?
    https://www.dropbox.com/s/a63mfc2c6ojr0tj/462ABFU0ITS-WK02-r98140.zip?dl=1
    Please also disable "Application Patrol" in Configuration and under Monitor (Collect Statistic) and let me know if it still happen.
    If yes, please send me diag file via PM.
    https://support.zyxel.eu/hc/en-us/articles/360001516479-USG-Series-Creating-A-Diagnostic-File
    Kind Regards,
    Tobias
  • neoforma
    there is no checkbox to disable App Patrol, so i deleted the profile from the list. is this right?
  • Zyxel_Tobias
    please go to Monitor -> UTM Statistic -> Application Patrol and disable "Collect Log"
