DV SSL or OV SSL or EV SSL
Hi @Amara,
Regarding to your questions, DV, OV, or EV certificate type, it just a validation method by CA, any certificate must be verified by the issuing Certificate Authority (or CA) to ensure that it is covering the correct, authorized site. USG can import these type certificate.
May I know where do we import the certificate in the USG?0
HI @Amara,
The menu path is on “Configuration > Object > Certificate”. There are two tabs in this page, one is “My Certificates”, another is “Trusted Certificates”.
To import a certificate into USG, two certificates are required. The first one is called the ROOT certificate, and it confirms the identity of the authority certificate organization,
the second certificate is purchased by the customer. You have to import both certificate to USG.
ok thanks.
Using USG210, any idea why when we are accessing our supplier SSL website, it will give an error? When we disabled the firewall, everything is fine. Can advise?
Hi @Amara,
What kind of errors? Do you apply SSL inspection on security policy rule? or any UTM profile apply on the security rule?
it is CA error0
Hi Amara,
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
