ZyWALL USG 300 - DASHBOARD FRONT PANEL
Hi link000,
not exactly sure ,what you mean, can you be more concreate?
Is it working in Chrome?
Kind Regards,
Tobias0 -
Hi Tobias. The router image disappeared altogether when Adobe Flash Player stopped working. The Ruffle plugin for Mozilla Firefox partially corrected the situation, the router panel began to be rendered in gray tones, but the active connections are not shown in color. In Chrome, there is an empty space instead of an image and an inscription that the Adobe Flash Player plugin is no longer supported.
Hi @link000
I understand.
I think we are not able to fix it due to USG300 is Phase Out already.
I tried it on USG310 and Flex500 which is the successor of USG300 and the issue didn´t happen here.
To get real information, you may use "show interface all" in SSH as workaround.
Kind Regards,
Tobias0 -
Tobias, thanks.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
