Usg20 Latest Firmware 2016?
DrZ
DrZ Posts: 1 image  Freshman Member
Second Anniversary
edited April 2021 in Security
Just bought a USG20W to get used go firewalling.
1. I recognized that the latest firmware available is from 2016. Ist the Model still supported?
2. i try to set up a simple firewall to allow only windows updates. where do i find a manual for this?
thanks
DrZ
    The USG20W is EOL only USG20W-VPN is up to date.
    Windows updates uses DNS and ports 80,443 not sure if the USG20W has address FQDN
