[Release Note] Nebula Security Gateway Series - Phase 3 firmware has been released!
Zyxel_Moderator
Zyxel Nebula Security Gateway Series
Release Note
April, 2018
Firmware Version on all models
Zyxel NSG50 - V1.20(ABHP.6)
Zyxel NSG100 - V1.20(ABEA.6)
Zyxel NSG200 - V1.20(ABLD.6)
New Feature and Enhancements
- Add Guest zone Interface addressing feature to help create an independent Internet accessing only LAN/VLAN.
- Supports to create the second peer IP for Non-Nebula VPN failover.
- Supports to use the source IP to do the ping check through Live tools of monitoring Security gateway.
Bug Fix of Major Release
- Fixed memory high when user enable Site-to-Site VPN, and the tunnel is connected 20 tunnels or above.
Notes
- To all users when upgrading Nebula devices, please make sure your device is connected to the control center and internet.
- During the upgrade process (notice the LED will flash in red rapidly), make sure the power is not inturruped or disabled, in the unlikely event of this happening, you may have to perform the upgrade again.
Nebula Forum Moderator
2
I like Guest zone to have an independent Internet easily! good to know!0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 346 Security Ideas
- 482 News and Release
