Restrict VPN access to one resource
dmmichael
dmmichael Posts: 16 image  Freshman Member
edited April 2021 in Security
Goodmorning everyone.
How can I make sure that a user who connects to my network in vpn can access only one server? (example on a server with ip 192.168.1.199)
Thank you
  • dpipro
    dpipro Posts: 73 image  ZCNE Certified
    First Comment Friend Collector Seventh Anniversary ZCNE Switch Level 1 Certification - 2020
    Hello @dmmichael,
    Is it a ZyWALL Series? Just configure a Security policy rule from IPSec_VPN to LAN
    Best regards
    Best regards
  • dmmichael
    Hello dpipro
    Zyxel USG210
    PeterUK Posts: 4,411 image  Guru Member
    Inactivate rule IPSec_VPN_Outgoing and SSL_VPN_Outgoing depending on the VPN type then you can make your own rule.
  • dmmichael
    Ok. I try Thanks
  • dpipro
    As PeterUK said:
    Here is an example,
    After disable the default policies you must create a rule IPSec (IPSec_VPN to LAN) or SSL (SSL_VPN to LAN) with the 192.168.1.199 as the IPV4 Destination address
    Best regards
  • dmmichael
    edited February 2021
    forgive me, I forgot to tell you that I already have an active ssl vpn, if I try to create a second one, the one above I asked you, it doesn't work. Maybe there is a limit to VPNs? licenses or other?
    Thank you
  • krp
    krp Posts: 5 image  Freshman Member
    can the nsg series do this too? or will it reguire usg series
  • dmmichael
    Solved. Thank you for support
