Restrict VPN access to one resource
Hello @dmmichael,
Is it a ZyWALL Series? Just configure a Security policy rule from IPSec_VPN to LAN
Best regardsBest regards0 -
Hello dpipro
Zyxel USG2100 -
Inactivate rule IPSec_VPN_Outgoing and SSL_VPN_Outgoing depending on the VPN type then you can make your own rule.0
Ok. I try Thanks
PeterUK said:Inactivate rule IPSec_VPN_Outgoing and SSL_VPN_Outgoing depending on the VPN type then you can make your own rule.
Here is an example,
After disable the default policies you must create a rule IPSec (IPSec_VPN to LAN) or SSL (SSL_VPN to LAN) with the 192.168.1.199 as the IPV4 Destination address
Best regards0 -
forgive me, I forgot to tell you that I already have an active ssl vpn, if I try to create a second one, the one above I asked you, it doesn't work. Maybe there is a limit to VPNs? licenses or other?Thank you0
can the nsg series do this too? or will it reguire usg series0
Solved. Thank you for support1
- 397 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 52 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
