Desktop Bitdefender GravityZone updates blocked by Zyxel's Bitdefender definitions
Sharing with others who are possibly trying to figure this out: as of Feb 17, Zyxel's anti-malware functionality on ATP/USG devices is detecting and blocking Bitdefender updates for internal desktop installations. Suspecting false-positive but can't be certain. Is anyone else experiencing this issue?
PS. I am not getting far with Bitdefender or Zyxel support. The best part of this is that Zyxel anti-malware is using Bitdefender engine/definitions!
Hi BCCThe ATP runs now with mcafee (sinc V 4.50 AFAIK)*First it was Kaspersky, then bitdefender for a short time and now mcafee.Do you have logs for the blocking?
Hi @BCC
Currently, the Anti-Malware of ATP is using Bitdefender.
And this symptom is the virus signature update won’t be forwarded to LAN's hosts which install Bitdefender anti-virus software.
The upcoming new Anti-Malware signature update will fix this symptom.
@Zyxel_Jeff isn't also Webroot used for some of ATP functionality? Does Zyxel have any information or documentation outlining which vendors are used for which feature of ATP? I couldn't find anything. Please share so we can distribute internally.
The fixed signature version is 2.1.x.20210222.0(included) later.
Please update to the latest Anti-Malware signature which fixed this symptom.
BTW, you can refer to this link regarding to Zyxel’s Alliance Partners.
https://www.zyxel.com/about_zyxel/alliance_partners.shtml
Thanks.
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
