Web console don't work for USG60W
PeterUK
PeterUK Posts: 4,552 image  Guru Member
edited April 2021 in Security
Odd one this as Web console on USG40/60 work fine with v4.62 but not for USG60W
Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request
Reason: Error reading from remote server
No proxy set same browser that works with USG40/60
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,393 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @PeterUK
    We tried with the same model without seeing this symptom.
    Can clean the cache and to open Web console in browser private mode help to this case?
    If this problem still appears, could provide your Web GUI remote access to us via private message for further investigation?
    Thanks.
    It was the first thing a did was clean the cache and it didn't work then I tried another browser and it worked I then found it must be a bad cookie and had to select "cookies and other sites data" which the worked.
