Restrict VPN access to one resource
Hello @dmmichael,
Is it a ZyWALL Series? Just configure a Security policy rule from IPSec_VPN to LAN
Best regardsBest regards0 -
Hello dpipro
Zyxel USG2100 -
Inactivate rule IPSec_VPN_Outgoing and SSL_VPN_Outgoing depending on the VPN type then you can make your own rule.0
Ok. I try Thanks
As PeterUK said:PeterUK said:Inactivate rule IPSec_VPN_Outgoing and SSL_VPN_Outgoing depending on the VPN type then you can make your own rule.
Here is an example,
After disable the default policies you must create a rule IPSec (IPSec_VPN to LAN) or SSL (SSL_VPN to LAN) with the 192.168.1.199 as the IPV4 Destination address
Best regards0 -
forgive me, I forgot to tell you that I already have an active ssl vpn, if I try to create a second one, the one above I asked you, it doesn't work. Maybe there is a limit to VPNs? licenses or other?Thank you0
can the nsg series do this too? or will it reguire usg series0
Solved. Thank you for support1
- 588 USG FLEX H Series
- 477 News and Release
ZCNE Certified
