Latest firmware update 2.60(AAHK.3) Gs1900-24E reset to factory default settings.
Have you remembered to save your configuration before you upgrade the firmware?
In my understanding, the counter should be reset if the Switch reboots.0 -
TomorrowOcean said:Have you remembered to save your configuration before you upgrade the firmware?
Hi @TomorrowOceanI will probably not. I assumed that update save and restore it by it self.Fortunately this was a backup switch so no harm happened.Thank you for your reply.
- 237 Nebula Ideas
- 6.8K Security
- 741 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
