XGS1210-12 disable QOS
paraplu
paraplu image  Freshman Member
edited August 2022 in Switch
Is there a way to turn off QOS settings alltogether?
  • Zyxel_Jason
    Zyxel_Jason image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @paraplu ,
    If the QoS setting on your XGS1210-12 is default like the screenshot below, it is the same concept that disable QoS on Switch because all ports are configured as same queue.
    Hope it helps.
    Jason
  • Zyxel_Jason
    Hi @paraplu ,
    Hope it helps.
    Jason
