UMTS Fallback during business hours
Hello Community,
today i have a more specific requirement.
Maybe there is a tested documentation at ZYXEL, which I don't know yet
Requirement
During office hours (9 a.m. to 6 p.m.), a connected UTMS stick to a USG should dial in if the broadband connection fails and take over operation until the broadband is reactivated.(for dedicated vLANs - not for all vLANs).
It should not be dial in if the broadband is dieconnected in the 24h cycle.
Is there any documentation/handout availible for this type of configuration ?
thx and best regards
Christian
Requirement
Christian
Hi @ChristianG,
It does not support dial in within a specific time frame. We only can set “Nailed-Up” to control the connection is always up or dial on demand.
Hi @Zyxel_Cooldia
thanks for the quick response. If it's not possible by a USG. Is it possible to connect a ZYXEL LTE 4506 to WAN2 and configure the described requirement ?
The SIM Card has no flatrate it's only to have a backup for VOIP and dedicated vLANs until broadband is down, or the USG wouldn't reconnecte in the night and require a manualy reset by a manualy powercycle
thx forward
Christian
Hi @ChristianG,
ZyXEL LTE 4506 does not have schedule dial in.
Maybe we can try another method, how about create 2 scripts on USG.
The 1st script is running to shut down the cellular interface at 6 p.m.
configure terminal
interface cellular1
shutdown
exit
The 2nd is cellular interface no shot down at 9 a.m.
configure terminal
interface cellular1
no shutdown
exit
Please note that “Nailed-Up” must enable on cellular interface.
Hi @Zyxel_Cooldia
the script idea looks good
there is a way to add "dependencies" to zyash scripts, e.g.
if WAN1 changed from "connected" to "disconnected" raise the "no shutdown" script to activate celluar connectivity if required and not permanent ?
thx for your service
Christian
Hi @ChristianG,
It does not support flow control on Shell Script.
e.g. IF else, for loop, and select case.
But we can add policy route with wan trunk, wan 1 is active mode, cellular is passive mode, then the traffic most time goes to wan 1, unless the wan 1 connectivity check fail.
- 384 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 79 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 909 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 898 Nebula FAQ
- 415 Security FAQ
- 234 Switch FAQ
- 205 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
