ATP500 limit throughout to 320Mbps
Hi guys,
I have an ATP500 with P2 - WAN1 set as in DHCP as per below pictures
The WAN1 is connected to a broadband gigabit supplier (Hyperoptic UK).
If I connect my laptop to the socket I get 493Mbps down and 535Mbps up.
If I connect the ATP500 to the socket and the laptop to the ATP500 then I get 320Mbps down and 535Mbps up.
The ATP is doing something to the down speed but I can't find anything into the config which would do this.
Can you please help?
here is the speed test with my laptop connected directly to the WAN cable.
https://www.speedtest.net/result/10995285509
and here is going through the ATP500
https://www.speedtest.net/result/10995298248
same server, same laptop, same cables.
test 1 - 11.50pm
test 2 - 11.53pm
it has to be something into the ATP500
maybe @Nebula_Chris can you help?
here is a website I was recommended by my broadband supplier
test with WAN going into ATP
http://hyperoptic.speedtestcustom.com/result/ad8d3eb0-77d0-11eb-a14d-913c54a65f61
test with WAN going into laptop directly
http://hyperoptic.speedtestcustom.com/result/59af8f40-77d1-11eb-93df-e162054c0888
as you can see the line from the socket is perfectly clean.
It's the ATP500 that is slowing it down.
please help
ATP Protection bundle is the issue!!!
I disabled everything and this is the outcome!!
I thought that the worst case scenario for an ATP500 was 890Mbps
HI, any help here please?0
Hi @Carlo
The throughput test results were measured by multi-session download/uplink in lab.
You can refer to another similar discussion as yours.
Thanks.
@Zyxel_Jeff
I think this could have been better explained on the website as your table there is very misleading.
I just made my customer upgrade from USG to ATP and now I don't know how to justify this £2k upgrade anymore.0
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
