ATP200 with slow RDP accesses
Pedro_Costa
Hello, I have an ATP200 installed in the office, and at the moment I have about 30 people working for RDP access in autocad. For them to be able to connect
without breaks and slowness, I am obliged to disconnect the security policies of ATP. Can someone help me what may be happening?
Hi @Pedro_Costa
We’re not clear about your question. Do you mean that you like to disable the security policy to speed up your RDP connection? Can you explain more detail?
Thanks.
Hi Zyxel_Jeff, I have the 30 people connected by ssl to the office, but due to complaints of slowness to work with autocad by RDP, I realized that only by turning off the security policy does it resolve. Because I don't want to have to turn off the security policy, I ask for your help. What can I do to overcome this situation?0
Hi @Pedro_Costa
You can enable BWM to prioritize your RDP service.
You can refer to this link:
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=012273&lang=EN
Thanks.
@Pedro_Costa Take care, RDP Uses Port 3389 TCP and UDP. The default port settings from Zyxel are TCP Only. This can have an big impact on performance, if RDP only works over TCP.0
Hi @Zyxel_Jeff and @Mario . I had already tested the Zyxel Jeff solution and it had not worked, I have now tested creating UDP port 3389 and joining services by group, but it did not work. The solution I found was to replace SSL connections with L2TP over IPSec. I don't know if it will have something to do with the difference in speed limitation between the different connections. But it got as fast as it did when security policies were off. Thanks so much for your help.0
Ok, this is sadly a know limitation. Secuextender is TCP based and an fast RDP Session needs UDP. In the end the UPD traffic is tunneld over TCP and this kills your performance.The only working way is to use IPSec or L2TP, as you already did.0
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 319 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
