Flash Usage and Update
Good day. I cannot update the firmware. every time an error is displayed: Update Standby Partition (Total: 0Mb) Error: Firmware update fail - checksum error: 400 I think this is due to the fact that Flash Usage is used by 96%. Am I right? How do I update the firmware?
My device - Zywall 1100
Boot to each firmware and remove any packet capture files and diagnostics files.0
Hi @FANAT
Please answer to following question in order for us to understand the problem;
1- What is current firmware version of Zywall 110?
2- Did you try after deleting unnecessary Configuration files(Maintenance > File Manager > Configuration File) and Diagnostic files(Maintenance > Diagnostics > Files) ?
3- Can you upgrade firmware by manually (Maintenance > File Manager > Firmware Management > Local Firmware ?)
In addition, you can try following command for cleaning flash usage and try again firmware upgrade;
GUI > Web Console
Router# debug system _disk-cleanup
Zyxel_CanThe instruction you sent did not help.I am using firmware versionV4.39 (AAAA.0).I downloaded the latest firmware 4.62 (AAAA.0) from https://portal.myzyxel.com/my/firmwares and updated it manually.The update was successful.Thank you for your quick response to my question.I received new knowledge from you.0
Good day, Zyxel_Can.
The instruction you sent did not help. I am using firmware version V4.39 (AAAA.0). I downloaded the latest firmware 4.62 (AAAA.0) from https://portal.myzyxel.com/my/firmwares and updated it manually. The update was successful. Thank you for your quick response to my question. I received new knowledge from you.
- 588 USG FLEX H Series
- 477 News and Release
