No more than 8 networks in SSL VPN
I have a SSL VPN setup with the SecuExtender software. Works very nice. However it is limited to 8 networks to connect to. I have tried to merge them into a group object but it does not show in the selection box. Is there a way to have more than 8 networks routed through the SSL VPN connection?
Regards,
Jeroen
Regards,
Jeroen
I have changed the mask to be smaller and thus the range bigger. Not very ideal but it will work for now.
How would that be when using a USG as a concentrator with more than 8 attached firewalls?
But hey, it's solved.
Jeroen0
Please answer to following questions for better understanding;
1 - What's the model name of the Zyxel device?
2- What's the firmware version for Zyxel device?
3 - Do you mean that you can't add more than 8 networks into Zyxel device's SSL VPN ? (Configuration > VPN > SSL VPN > Access Privilege )
4 - How did you merge them into a group object?
5 - Can you provide a screenshot that it shows 8 networks limitation?
Best regards.
1 - Model is Zywall310.
2 - Firmware is 4.62(AAAB.0).
3 - When adding the 8th network into the address objects the message as in the picture pops up.
4 - I have created the network subnets as address/subnet objects and then created an address group out of them.
5 - Screenshot included below.
Hi @AHGJSoree,
Currently SSL VPN can't add more than 8 networks into Network List.
You may modify your subnets with smaller subnet masks.(Ex: /22 instead of /24).
Then you can create address objects with the smaller subnet masks.
Jeroen0
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
