Issues regarding policy routes
Dano89
Dano89 Posts: 3
edited April 2021 in Security
Hey everyone,
I do not know if it is a configuration issue but my policy routes do not seem to work correctly.
Basically, I am trying to route 3 VLANs to a router (it is a router connected to a MAN so everything is private ip addressed, our ISP's MPLS network route our subnets to our different DCs and to Internet):
Vlan 11 10.0.0.0/24 Gateway 10.0.0.2/24 (interface vlan 11)
Vlan 12 10.0.1.0/24 Gateway 10.0.1.1/24 (interface vlan 12)
Vlan 13 10.0.2.0/24 Gateway 10.0.2.1/24 (interface vlan 13)
Router's IP is 10.0.0.1/24
Our DC has a 10.0.3.0/24 network that has to be allowed to reach these 3 VLans
Uplinks are tagged correctly. The FW - Router uplink goes through a L2 switch, untagged on Vlan 11
Policy routes:
1) Incoming: Interface vlan12 Source Address 10.0.1.0/24 Dest: Any Service: Any Next Hop: Gateway 10.0.0.1
1) Incoming: Interface vlan13 Source Address 10.0.2.0/24 Dest: Any Service: Any Next Hop: Gateway 10.0.0.1
Policy rules:
Anything that comes from this 3 subnets can go everywhere.
FROM (Vlan11, Vlan12, Vlan13) TO ANY IPv4 Src Vlan11's subnet, Vlan12's subnet, Vlan13's subnet IPv4 Dst Any Action allow
Subnet 10.0.3.0/24 should reach the 3 Vlans.
FROM any TO (Vlan11, Vlan12, Vlan13)  IPv4 Src 10.0.3.0/24 IPv4 Dst Vlan11's subnet, Vlan12's subnet, Vlan13's subnet Action  allow
From my MAN, I can ping the 3 Gateways 10.0.0.2, 10.0.1.1, 10.0.2.1 and the router 10.0.0.1.
However, I am not able to ping any clients connected to these 3 Vlans.
From my LAN, I cannot reach my DC's network 10.0.0.3/24. Inter vlan routing is working
I hope it is clear :)
Any ideas?
Thanks in advance.
    PeterUK Posts: 3,983  Guru Member
    edited March 2021
    What USG are you using?
    So LAN1 on the untagged interface is not used by the looks of it (give it some other adders not to conflict with VLAN 11 so its gateway can be 10.0.0.1) and your WAN IP is in 10.0.3.0/24 ?
    You might not be doing the tags/untag correctly and Policy routes to a gateway thats not in use looks wrong.
    I'm having a hard time working out what you have done maybe a draw up would help me get a idea of the WAN and LAN with VLAN's in which zone.
    I take it PC's on like VLAN 12 don't have internet or do they?
    On 10.0.3.0/24 network what is the IP and gateway on what interface is getting?
  • Dano89
    Dano89 Posts: 3
    It is USG 310 v 4.38.
    Here is the diagram:
    The goal is to direct traffic from VLANs 11, 12 & 13 to 10.0.3.0/24 using Policy Routes because we cannot use static routes (there are other LANs' traffic routed to another ISP router).
    10.0.30/24 hosts should be able to access LAN 10.0.0.0/24, 10.0.1.0/24, 10.0.3.0/24
    Here are the Policy Routes: (ISP = 10.0.0.1)
    index: 2
      active: yes
      auto-disable: no
      description: VLAN13
      user: any
      schedule: none
      interface: vlan13
      tunnel: none
      sslvpn: none
      source: SUBNET_VLAN13
      destination: any
      DSCP code: any
      service: any
      srcport: any
      nexthop type: Gateway
      nexthop: ISP
      nexthop state: Not support
      auto destination: no
      SNAT: none
      DSCP marking: preserve
      connectivity-check: no
    index: 3
      active: yes
      auto-disable: no
      description: VLAN12
      user: any
      schedule: none
      interface: VLAN12
      tunnel: none
      sslvpn: none
      source: SUBNET_VLAN12
      destination: any
      DSCP code: any
      service: any
      srcport: any
      nexthop: ISP
      SNAT: none
    One remark: The option Use IPv4 Policy Route to Override Direct Route is disabled. This might be the problem since I want to direct VLAN 12 & 13 to 10.0.0.1 and they should not use the directly connected routes.
    Thanks.
    I think the problem is you trying to get more subnets by VLAN 11 if you remove VLAN 11 the tagged network so that you have the USG 10.0.0.2 to 10.0.0.1 router with Use IPv4 Policy Route to Override Direct Route it might all work?
    Sorry I can't be more help I think someone else can help you more with your setup.
  • Dano89
    Dano89 Posts: 3
    Well, thanks very much for your help. The VLAN 11 is in fact used as a "transit network" if you know what I mean.
    I've run a simulation unsing GNS3 and it is correctly working but with a Cisco L3 switch instead of the USG 310.
    My assumption is perhaps that I am not configuring these policy routes correctly. And I am not really familiar with Zyxel products to be honnest.
    Do you know the impacts of this feature "Use IPv4 Policy Route to Override Direct Route" in a production environment?
    I used the feature "Use IPv4 Policy Route to Override Direct Route" here in this setup.
    https://community.zyxel.com/en/discussion/9773/local-static-routes-not-working#latest
    Instead of sending traffic out the interface it knows directly it instead sends it to the set gateway next hop.
