Flash Usage and Update
FANAT
FANAT Posts: 12 image  Freshman Member
edited April 2021 in Security
Good day.
I cannot update the firmware. every time an error is displayed:
Update Standby Partition (Total: 0Mb)
Error: Firmware update fail - checksum error: 400
I think this is due to the fact that Flash Usage is used by 96%.
Am I right?
How do I update the firmware?
  • FANAT
    My device - Zywall 110
    PeterUK Posts: 4,411 image  Guru Member
    Boot to each firmware and remove any packet capture files and diagnostics files.
  • Zyxel_Can
    Zyxel_Can Posts: 342 image  Zyxel Employee
    25 Answers First Comment Friend Collector
    Hi @FANAT
    Please answer to following question in order for us to understand the problem;
    1- What is current firmware version of Zywall 110?
    2- Did you try after deleting unnecessary Configuration files(Maintenance > File Manager > Configuration File) and Diagnostic files(Maintenance > Diagnostics > Files) ?
    3- Can you upgrade firmware by manually (Maintenance > File Manager > Firmware Management > Local Firmware ?)
    In addition, you can try following command for cleaning flash usage and try again firmware upgrade;
    GUI > Web Console
    Router# debug system _disk-cleanup
  • FANAT
    Zyxel_Can
    The instruction you sent did not help.
    I am using firmware version
    V4.39 (AAAA.0).
    I downloaded the latest firmware 4.62 (AAAA.0) from https://portal.myzyxel.com/my/firmwares and updated it manually.
    The update was successful.
    Thank you for your quick response to my question.
    I received new knowledge from you.
  • FANAT
    Good day, Zyxel_Can.
    V4.39 (AAAA.0).
