NWA210AX - Unable to delete default cert
Human_USB
Human_USB Posts: 6 image  Freshman Member
edited May 2024 in Wireless
Howdy,
Device: NWA210AX
Firmware: V6.10(ABTD.8) / 2020-10-06 14:37:16
Object: Auth. Server
Error: 404 - Not Found
Mode: Stand-alone
I imported my own cert, and now I'm trying to remove the default self-sign cert but I'm running into issues. I see the object is used by "Auth. Server", but when I click on it, I get an error "404 - Not Found". Help?
  • Zyxel_Freda
    Zyxel_Freda Posts: 397 image  Zyxel Employee
    25 Answers First Comment Friend Collector Third Anniversary
    Hi @Human_USB,
    Thanks for reporting this issue. It's can be reproduced and we'll update for you about fixing this issue.
  • Human_USB
    edited March 2021
    I was able to fix it manually by editing the Auth Server via CLI:
    Now my config looks like this:
    auth-server cert <CERT NAME HERE>
    Please log this as a bug. :)
  • Zyxel_Freda
    Hi @Human_USB,
